When it comes to cleaning floors, Cox Industries is the expert. Our commercial degreaser products, Soybase Clean, are great for any type of floor surface. When you need a tough, yet safe, industrial degreaser there is really only one choice. Our products work great in any season, both indoors and out. When you need a strong industrial degreaser for wet mopping, try Soybase Clean Original. Stains do not stand a chance when you incorporate Soybase Clean into your cleaning tool belt. Wet mopping can be a job everyone dreads. In some industries, wet mopping might be required hourly. We put together a list of a few tips that we guarantee will make this task a little easier.
The Tips
Always wet mop to clean a floor faster and more efficiently. Make sure you are using adequate commercial degreaser products. One of the biggest mistakes one can make when wet mopping is not using enough cleaning solution. This can really prolong the time it takes to finish the job. Wet mopping is great for spot cleaning and Soybase Clean should be your go-to spot removing commercial degreaser. Make sure you’re really soaking your mop into your cleaning solution for optimal cleaning performance. This will make your job easier and ensure a proper cleaning. Not using enough floor cleaner degreaser products might mean having to repeat the job several times just to clean one area.
This being said, you will also need to make sure you are changing out your water and commercial degreaser solution more often. I have no idea why someone would even try to clean a floor with a mop bucket full of black and dirty liquid, but it does happen. Using a bucket full of dirty water will not help you clean your floors any faster. As a matter of fact, you are just creating more work for yourself. Changing out your commercial degreaser cleaning solutions more frequently will ensure an efficiently cleaned floor surface.
Make sure to change out your old and dirty mop heads more frequently. Also, make sure you are color coding your mopping equipment. For instance, you wouldn’t want to use a dirty mop from the bathroom to clean the kitchen floors. The same could be said about using a greasy kitchen mop to clean the front lobby. Using the same mop heads over and over will increase soil load making the mop head really inefficient. After a certain point, a dirty mop head will not clean anything and you will just be spreading dirt around.
All mops are not the same and some mops should not even make the cut. For instance, try to stay away from cut end mops and use looped end, or microfiber instead. Looped end and microfiber mops are great for most all surfaces, absorb more liquid, and are virtually lint-free. These types of mops also cover a wider cleaning area meaning you can clean more surface area in fewer minutes.
Commercial Degreaser Products For Better Mopping
At Cox industries, we have been perfecting our commercial degreaser products for over thirty years. We make products for the hardworking men and women in the cleaning industry. We understand how tough your jobs can be. If you want to work smarter, and not harder then please call our friendly reps today and ask about the best industrial and commercial degreaser products on the market – SoyBase Clean.
