Remove tire marksTrying to remove tire marks can be the bane of some people’s existence. I bet some of you reading this even consider these unsightly leftovers your mortal enemy. Did you know that SoyBase Clean is number one in removing tire marks quickly and easily? Our family of industrial degreaser products works to rid your floor’s surface of tire marks, both indoors and outdoors, without you having to break your back, or bank account. Call us today for a free sample.
As one of the nation’s leaders in cleaning solutions, we get asked a lot of questions. One of the most common is why tires leave rubber marks on the floors, and then subsequently how to remove them.
For starters, the leftover tire marks that you’re seeing are called plasticizers. Plasticizers are made up of different polymer compounds that make rubber tires more flexible. Making tires more flexible gives them more traction, and helps keep them soft and pliable in cold weather. However, the byproduct of these compounds is called plasticizer migration.
This is the process that causes tires to leave black rubber marks behind all over your floors. It mainly happens because tires heat up after being used and this causes the plasticizers to leach out and build up. Unfortunately, if you allow your vehicle to sit for long periods without moving, the same process will occur but at a much slower pace. It seems that plasticizer migration issues are more noticeable with high-quality performance and all-season tires.
How Do You Remove Tire Marks?
To remove tire marks from your floor, you can take the hard route or the easy route. First, you should evaluate how long the tire marks have been building up. This will help you determine the best tools and technique to get the job done quickly and easily. If the tire marks are fresh and fairly new, then you should use a scrub brush and SoyBase Clean Pre-treatment. Follow the dwell times and away you go.
For the ones that are more stubborn and have built up overtime, use SoyBase Clean Xtreme. This heavy duty cleaner degreaser is 8 times the strength of our original solution and can be used on all stains. To make the job easier, combine Xtreme with an industrial floor scrubber for quick and easy action.
Remove Them with Ease | SoyBase Clean
When it comes time to remove tire marks and clean your floors, invest in your team by providing them with the right tools to get the job done quickly, efficiently, and easily. Call Cox Industries now and ask about SoyBase Clean. Our products are the top industrial degreaser cleaners on the market and the number one Tennant floor scrubber solution. Using our family of cleaning solutions helps you remove buildup of dirt, oil, and other tough stains. Send us a purchase order early enough and we can ship your order out the same day. Call us today to get your free sample of SoyBase Clean today.
